STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1589 Views
  • 0 replies
  • 2 kudos
How to enable HAL_UART_RxCpltCallback?
I've reviewed numerous similar posts and the UART_TwoBoards_ComIT example, but have found no solution. My code is being generated by Cube 6.6.1 for the STM32F446. The UART5 Global Interrupt is enabled. My code and the example code both contain UART5_...
DBroo.1 by Associate III
  • 18158 Views
  • 9 replies
Resolved! Can STM32F301 use 3 I2C simultaneously?
hello. I've never used STM32 before.I'm trying to use it this time. It requires several pins of GPIO and 3 channels of I2C.I searched and the STM32F301 seemed suitable, so I designed a circuit using it.I tried setting the PIN using a setting tool cal...
KLEE.2 by Associate II
  • 3282 Views
  • 4 replies
Resolved! Problem with STM32C031K6 and ADC DMA
Hello,I am testing a STM32C0 MCU to see if it might be good for a project I'm working on attracted by the price point, but I have to say that I have some unexpected problem.Among several the most relevant is multichannel DMA based ADC conversion that...
0693W00000aHEa2QAG.png 0693W00000aHEl4QAG.png 0693W00000aHEYbQAO.png 0693W00000aHElsQAG.png
FCamp.1 by Associate III
  • 5771 Views
  • 9 replies
STM32L072C6T6 LPUART DMA interrupt need Reset MCU to works
Hi everyone,I'm working on a project with an STM32L072C6T6.I'm using LPUART1 DMA to get data from my LPUART with interrupt when the bus go idle.My soft working when, after power on the device, i push the reset button of the MCU. All start correctly.B...
MLam by Associate III
  • 5170 Views
  • 3 replies
