STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1547 Views
  • 0 replies
  • 2 kudos
Unable to save any projects in STM32CubeMX
Hello,I've been having difficulties saving projects in STM32CubeMX. I've tried versions 6.8.1, 6.8.0 and 6.7.0, as well at the latest versions of Java SE 20, 19 and 17.Saving has worked exactly once, the window no longer opens whenever saving is invo...
Resolved! Board number not found in the pack installer tab
Hi all,We are about to start evaluation in the following development environment specified by the module manufacturer.ST Micro NUCLEO-L073RZKeil μVision V5 ( V5.29 )STM32cubeMX  (V 6.0.1 ,STM32Cube MCU Package for STM32L0 1.11.3)We cheked the Pack In...
sss_jpn by Associate II
  • 1540 Views
  • 1 replies
STM32Cube_FW_L0_V1.11.3 not select
Hi all,We are about to start evaluation in the following development environment specified by the module manufacturer.ST Micro NUCLEO-L073RZKeil μVision V5 ( V5.29 )STM32cubeMX (V 6.0.1 ,STM32Cube MCU Package for STM32L0 1.11.3)    Attached files are...
  • 1538 Views
Console output to text file
I am using NUCLEO-F401RE board with X-NUCLEO-IKS01A3 extension board for a pedometer application. The sensor data from board is displayed on Command Shell Console in STM32CubeIDE but want this data is text or csv file for further analysis. Can somebo...
Resolved! Enable LWIP without ETH IP in CubeMX
Hello,I am working with a STM32H743 and an Ethernet controller which I drive with SPI.So I don't use the ETH config in CubeMX (and I can't because pins are already taken by other functionalities), but I'd like to use the LWIP package which can't be e...
_legacyfs_online_stmicro_images_0693W00000dDPKcQAO.png _legacyfs_online_stmicro_images_0693W00000dDPKmQAO.png
SMari.10 by Associate II
  • 3838 Views
  • 1 kudos
