STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1547 Views
  • 0 replies
  • 2 kudos
does stm32f103c8t6 support external loopback?
I wrote a code for this microcontroller to test the CAN protocol, and it worked successfully in loopback test mode—data was transmitted and received correctly without using any external CAN transceiver. Then, I switched the CAN mode from loopback to ...
Resolved! DFSDM filtre synchronization issue in CubeMX
  Moved from STM32H7B0 DFSDM Synchronization: Abnormal Clock Output During Register Configuration to a new thread in STM32CubeMX forum.   Thank you for your detailed instructions!I set a breakpoint as you suggested and found that the audio clock is ...
wenjing_0-1747380862890.png wenjing_1-1747381044407.png wenjing_2-1747381112081.png
wenjing by Associate II
  • 1761 Views
  • 3 replies
  • 1 kudos
[STM32CubeMX 6.14.1] text garbling
When I generated the source code with STM32CubeMX 6.14.1, my Japanese comments in USER CODE area are garbled. The character code is Shift_JIS. The version 6.12.1 is no problem.Could you please confirm and modify ASAP?
MTana.1 by Associate III
  • 3807 Views
  • 8 replies
Resolved! HSI16 and sysclock configuration using Cube
 Hello, I'm new to ST platform and I would like to understand about clock configuration.I'm using NUCLEOU545REQ board for my development and want to know how to enable HSI16 clock and configure system clock to 24Mhz using stm32cubeGUI.
