STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1578 Views
  • 0 replies
  • 2 kudos
Standard Peripheral Library vs STM32CubeMX(HAL) library
Posted on April 29, 2017 at 17:30As title, what is different betweem stm32f10x-standard-library& # library. Shall we makeSTM32CubeMX to usestandard peripheral library?If possible, please let me know how to do detail.Also, what is different of stm32...
L C by Associate II
  • 5223 Views
  • 7 replies
Resolved! CubeMX v4.20.0 bug in clock configuration?
Posted on March 22, 2017 at 23:04When I generate code for STM32L151CBTx (FW v1.6.0) using CubeMX it enables MCI clock (RCC_ORCILLATORTYPE_MSI) in SystemClock_Config even if only HSI is enabled in the CubeMX clock configuration UI. Similar problem do...
STM32F7 - HSI configuration
Posted on March 21, 2017 at 13:12Hi,I am trying to configure a project in a STM32F769I-DISC1 board using TIM6, DAC1, the FMC connected to the external SDRAM and the DMA (to pass data between SDRAM and DAC).I have generated the configuration using ST...
Resolved! Bugreport STM32CubeMX 4.20
Posted on March 13, 2017 at 15:52 1. Faulty code generation STMCube Generates to following code in the function: void SystemClock_Config(void) RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSE;�? this resul...
Resolved! STM32CubeMX 4.20 Clock Config Bug
Posted on April 03, 2017 at 18:07Hey, I just updated my version of STM32CubeMX to 4.20 and now when I generate a project for the STM32F401VCTX using only the RCC-> HSE (A crystal not the internal clock) it gets stuck in SystemClock_Cofig(void). I wa...
STM32CubeMX: what kind of discovery board is meant?
Posted on April 23, 2017 at 21:13I wanted to create a project for STM32F407G-DISC1 board (STM32F4DISCOVERY?) but saw two identical lines in the selection dialog (see attach). What kind of discovery board is meant? Or is this mistake?STM32CubeMX 4.20...
STM32F7 - basic LwIP without FreeRTOS
Posted on February 09, 2017 at 16:32 Hello, I am using STM32F769I-DISCO board and CubeMX-generated project (v4.19) for this specific board. I am having troubles to makeminimal working firmware that can just respond to ping sent from my PC. ...
