STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1570 Views
  • 0 replies
  • 2 kudos
Resolved! Prescaler and period values for PWM in STM32
I am using STM32F103C8Tx and I am trying to create a PID adjustable PWM. In PID I will be giving values to PWM from 0 to 100 to set the duty cycle. That means my counter period needs to be 100 in Cubemx. Because as I have learnt while I am changing t...
GunkutA by Senior
  • 13506 Views
  • 17 replies
STM32H745ZI-Q Nucleo Ethernet is not working.
Hi,I have STM32H745ZI-Q Nucleo board. I have generated code using STM32CubeMX firmware version H7 1.5.0 (SW4STM32). I have enabled the LwIP Netconn and Ethernet for M7 core in STM32CubeMX. The issue is that it doesn't assign the IP address using DHCP...
I have an issue with ADC and Vrefint
Hi,I working with an STM32L010 controller. I have a confusing issue with one of ADC channel.Here is the configuration:I using ADC channels 1, 3, 6 and Vrefint.Here is the ADC configuration:I forgot the clock configuration:My problem is while the volt...
anagy9 by Associate II
  • 1461 Views
  • 1 replies
Resolved! STM32CubeMX fails under Fedora32
After a fresh install of Fedora32 STM32CubeMX fails to start. The error msg is the same for a freshly installed 5.6.1 as for the previously installed 5.6.0 (which worked under Fedora31).Has anybody a clue how to proceed? The error message is a follow...
THoff.1 by Associate
  • 1191 Views
  • 1 replies
STM32CubeMX version in the STM32CubeIDE
I tried this wayFile >> New >> STM32 Project From STM32CubeMX .ioc File.Selected the CubeMX .ioc fileClick FinishThen, CubeIDE says belowThis file has been generated with STM32CubeMX version '5.6.1'.Your current STM32CubeMX version is '5.6.0'.Please ...
