The system time
rokasjsutkus
Posted on August 05, 2016 at 11:56
I wanted to try out the CubeMX. I'm a bit stuck with some time issues. In standard peripheral I used system_get_time();
What is the equivalent of this function in CubeMX?
I found HAL_RCC_GetHCLKFreq(); that could be in my case, but it doesn't really work out for me, or at least I don't know what is the difference between them two.
#cubemx #system_get_time
Posted on August 05, 2016 at 17:14
Which SPL was that? HAL uses the SysTick with HAL_IncTick() to increment uwTick, which can be read using HAL_GetTick()
