Some problems in STM32CubeMX Version 4.25.1
op3 op3
Posted on May 24, 2018 at 09:10
Extra line  Rank 1
and the code is generated the same
ADC3 stopped working
How to fix the problem?
#stm32cubemx #adc3 #stm32cubemx-4.25.1
Houda GHABRI
Posted on May 28, 2018 at 11:21
Hi
Vid.Max
Thanks for your feedback.
This issue will be fixed in a next CubeMX release (4.1).
Houda
5 REPLIES 5
op3 op3
Posted on May 24, 2018 at 09:22
line ADC3.  in .ioc file
ADC3.Channel-0\#ChannelRegularConversion=ADC_CHANNEL_9
ADC3.Channel-205\#ChannelRegularConversion=ADC_CHANNEL_14
ADC3.Channel-206\#ChannelInjectedConversion=ADC_CHANNEL_4
ADC3.Channel-207\#ChannelInjectedConversion=ADC_CHANNEL_15
ADC3.Channel-208\#ChannelInjectedConversion=ADC_CHANNEL_6
ADC3.Channel-209\#ChannelInjectedConversion=ADC_CHANNEL_7
ADC3.Channel-210\#ChannelRegularConversion=ADC_CHANNEL_4
ADC3.Channel-IN14=ADC_CHANNEL_14
ADC3.Channel-IN15=ADC_CHANNEL_15
ADC3.Channel-IN4=ADC_CHANNEL_4
ADC3.Channel-IN6=ADC_CHANNEL_6
ADC3.Channel-IN7=ADC_CHANNEL_7
ADC3.Channel-IN8=ADC_CHANNEL_8
ADC3.Channel-IN9=ADC_CHANNEL_9
ADC3.ClockPrescaler=ADC_CLOCK_SYNC_PCLK_DIV8
ADC3.ContinuousConvMode=DISABLE
ADC3.DMAContinuousRequests=ENABLE
ADC3.DataAlign=ADC_DATAALIGN_RIGHT
ADC3.DiscontinuousConvMode=DISABLE
ADC3.EOCSelection=ADC_EOC_SEQ_CONV
ADC3.EnableAnalogWatchDog=false
ADC3.ExternalTrigConv=ADC_SOFTWARE_START
ADC3.ExternalTrigConvEdge=ADC_EXTERNALTRIGCONVEDGE_NONE
ADC3.ExternalTrigInjecConv=ADC_INJECTED_SOFTWARE_START
ADC3.ExternalTrigInjecConvEdge=ADC_EXTERNALTRIGINJECCONVEDGE_NONE
ADC3.IPParameters=Channel-IN4,Channel-IN6,Channel-IN7,Channel-IN8,Channel-IN9,Channel-IN14,Channel-IN15,ClockPrescaler,Channel-205\#ChannelRegularConversion,master,NbrOfConversion,NbrOfConversionFlag,Channel-0\#ChannelRegularConversion,Resolution,DataAlign,ScanConvMode,ContinuousConvMode,DiscontinuousConvMode,DMAContinuousRequests,EOCSelection,ExternalTrigConv,ExternalTrigConvEdge,InjNumberOfConversion,EnableAnalogWatchDog,Rank-0\#ChannelRegularConversion,SamplingTime-0\#ChannelRegularConversion,Rank-205\#ChannelRegularConversion,SamplingTime-205\#ChannelRegularConversion,Rank-206\#ChannelInjectedConversion,Channel-206\#ChannelInjectedConversion,SamplingTime-206\#ChannelInjectedConversion,InjectedOffset-206\#ChannelInjectedConversion,Rank-207\#ChannelInjectedConversion,Channel-207\#ChannelInjectedConversion,SamplingTime-207\#ChannelInjectedConversion,InjectedOffset-207\#ChannelInjectedConversion,Rank-208\#ChannelInjectedConversion,Channel-208\#ChannelInjectedConversion,SamplingTime-208\#ChannelInjectedConversion,InjectedOffset-208\#ChannelInjectedConversion,Rank-209\#ChannelInjectedConversion,Channel-209\#ChannelInjectedConversion,SamplingTime-209\#ChannelInjectedConversion,InjectedOffset-209\#ChannelInjectedConversion,Rank-210\#ChannelRegularConversion,Channel-210\#ChannelRegularConversion,SamplingTime-210\#ChannelRegularConversion,ExternalTrigInjecConv,ExternalTrigInjecConvEdge,InjectedConvMode
ADC3.InjNumberOfConversion=4
ADC3.InjectedConvMode=None
ADC3.InjectedOffset-206\#ChannelInjectedConversion=0
ADC3.InjectedOffset-207\#ChannelInjectedConversion=0
ADC3.InjectedOffset-208\#ChannelInjectedConversion=0
ADC3.InjectedOffset-209\#ChannelInjectedConversion=0
ADC3.NbrOfConversion=2
ADC3.NbrOfConversionFlag=1
ADC3.Rank-0\#ChannelRegularConversion=1
ADC3.Rank-205\#ChannelRegularConversion=1
ADC3.Rank-206\#ChannelInjectedConversion=1
ADC3.Rank-207\#ChannelInjectedConversion=2
ADC3.Rank-208\#ChannelInjectedConversion=3
ADC3.Rank-209\#ChannelInjectedConversion=4
ADC3.Rank-210\#ChannelRegularConversion=2
ADC3.Resolution=ADC_RESOLUTION_12B
ADC3.SamplingTime-0\#ChannelRegularConversion=ADC_SAMPLETIME_480CYCLES
ADC3.SamplingTime-205\#ChannelRegularConversion=ADC_SAMPLETIME_480CYCLES
ADC3.SamplingTime-206\#ChannelInjectedConversion=ADC_SAMPLETIME_480CYCLES
ADC3.SamplingTime-207\#ChannelInjectedConversion=ADC_SAMPLETIME_480CYCLES
ADC3.SamplingTime-208\#ChannelInjectedConversion=ADC_SAMPLETIME_480CYCLES
ADC3.SamplingTime-209\#ChannelInjectedConversion=ADC_SAMPLETIME_480CYCLES
ADC3.SamplingTime-210\#ChannelRegularConversion=ADC_SAMPLETIME_3CYCLES
ADC3.ScanConvMode=ENABLE
ADC3.master=1
Khouloud GARSI
Posted on May 24, 2018 at 09:42
Hi
Vid.Max
Could you please precise the device you're using and if possible share your complete ioc file.
Khouloud.
Posted on May 24, 2018 at 10:05
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6u1&d=%2Fa%2F0X0000000bxg%2FPRqzGRYWnMhb9Wb2qD9ehl18t7qBQFKjHokoCwssdH4&asPdf=false
Posted on May 24, 2018 at 11:39
Hello
Vid.Max
This forwarded to our CubeMX team. One of our experts will answer you ASAP.
Khouloud.
Houda GHABRI
Hi
Vid.Max
Houda
