STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1560 Views
  • 0 replies
  • 2 kudos
Resolved! TIM2->CCR2 Value Always Zero
Hi,I am running Capture Mode at TIM2 channel 1. My CubeMx configuration below. I am getting CCR1 value correctly but i checked at debugger mode, CCR2 value is always 0. Thus i can't measure duty. What's the problem ?
PWM+DMA STM32F103 issue
Hi everyone,I meet some issue about PWM + DMA on STM32F103 (Bluebill KIT).I generate 7 pulses with frequency 1Mhz and duty cycle of pulses is 50,30,50,50,70,50,0% sequence.But the result have some issue:On my OSC, i see 9 pulses and it more than i ne...
0693W00000FCxqjQAD.jpg 0693W00000FCxW5QAL.png 0693W00000FCxY1QAL.png 0693W00000FCxZsQAL.png
PTai by Associate
  • 1989 Views
  • 3 replies
STM32H7 SPI Issues
Hello, I am running into an issue using the SPI functionality on my STM32H7 chip that is on a custom made board. What I am trying to do is read an adas3022 adc (Link to datasheet below) on a spi peripheral from the STM32H7. I have written functions f...
0693W00000FCia7QAD.png 0693W00000FCiaCQAT.png 0693W00000FCiZbQAL.png 0693W00000FCiaHQAT.png
MAgui.1 by Associate II
  • 2515 Views
Cannot select different HAL timebas
Hello All, I am trying to start a new project which is suppose to run freertos.Once I have enable it then genertaing the code give below warning:  But when I try to change the timebase to TIM6, the option is disabled I have enabled TIM6 as below:  Ca...
0693W00000FCyWLQA1.png 0693W00000FCyWuQAL.png 0693W00000FCyRRQA1.png 0693W00000FCyXdQAL.png
HKapo.1 by Associate III
  • 1082 Views
  • 1 replies
Linker directive different when generating Makefile build
Hi - I'm working on some projects with STM32CubeIDE (1.6.1) and CubeMX (). What I've noticed is that if I generate a CubeMX project targeting a Makefile build the linker directive that is generated has some non-trivial differences with the .ld gener...
MMedv by Associate II
  • 1036 Views
  • 0 replies
  • 1 kudos
