MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! How to get yaw angle from IMU 10 dof (GY-86 MPU 6050 and HMC5883l)
I have the imu 10dof and i got raw data of accelerometer, gyroscope and magnetic. And i calculate the roll, pitch, yaw base on equation same in picture. i had calibrate accelerometer and magnetic. in the picture, show the data of magnetic before and ...
KNguy.11 by Associate
  • 3462 Views
LSM303C Click event setup
LSM303DLH has CLICK register to setup it but LSM303C has only commont THS and DUR registers set, can I use it to detect single tap event? As I understand I can setup AND config for all axis, but it doesnt work so good and I can get false detection fo...
Resolved! ST-EVALMKI212V1 not recognized on ST-EVAL109V3 ?
Dear ST Community,Ten days ago I already asked this support request but no one single response came from ST.I just bought and received an ST-EVALMKI109V3 + ST-EVAL212V1 after attending the webinar "Develop effective AI solutions for monitoring vehic...
tlamotte9 by Associate II
  • 3809 Views
  • 8 replies
Resolved! LIS2DW12 reserved pin functionality
Hi,I am debugging my custom board where I soldered an LIS2DW12 accelerometer on it. I forgot to pull the reserved pin ( 7 ) to ground as suggested in the datasheet. This is how I connected it:This is how it should be connected:Is this required, that ...
CMoeb.1 by Associate
  • 1357 Views
  • 1 replies
How to convert G to dbVrms
Hello Team,We would like to measure the vibration using LIS2DW12 (3-axis MEMS accelerometer), from the LIS2DW12 we were getting units in 'g' or 'mg'.Please let us know the possibility of converting g to dbVrms.Best regards,Abishek Devan
Resolved! LSM6DSL vs LSM6DSR with (Acc/Gyro) INT1 issue
Hi, We have a PCB design which used to have LSM6DSL and we were using ACC/GYRO data from the sensor. Since we switched to the new LSM6DSR chip the INT1 does not trigger (when data is ready) anymore even though the sensor should be similar config (if...
AHuta.1 by Associate
  • 1574 Views
  • 1 replies
