MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
STEVAL-MKSBOX1V1 streaming to usb
dear all, i want to recoed acceleration date from LSM6DSOX . i made app on st app and made output rate 6666 and output stram to usb. the proplem is i use python to read date from port with serial but the bytes mismatch because the sensor starts strea...
Resolved! ISM330DHCX vs ISM330BX vs LSM6DSV32X
We need ~50k 6-axis IMUs for an application that will experience > 2000dps yaw rate and highly dynamic motion. The spec sheets for the ISM330BX and LSM6DSV32X seem to not paint a complete picture regarding the angular zero-rate at different G_FS angu...
phly by Associate II
  • 2002 Views
Resolved! ISM330 - Experiencing strange behaviour with sensor fusion
Hello everyone,I'm currently in the process of integrating the ISM330BX IMU to a sensor i'm developping.So far, I have been able to implement this component to my design, communicate with it and read acceleration/gyroscope data.However, the reason th...
Mr_JM by Associate
  • 842 Views
  • 1 replies
LSM6DSL Accelerometer step count
I am using the kernel driver for accelerometer i need to find the accurate step count.Below are the reading for accelerometer from the driver from sysfs parameters and how can i find the step count,root@antler_xedge:/sys/bus/iio/devices/iio:device2#l...
Negative X-Axis Clipping on IIS3DWB When Stationary
Dear All,We are using the IIS3DWB MEMS accelerometer in one of our products and have encountered an issue with a single unit that we would like your input on. Issue description:On this specific device, the X-axis always reports the maximum negative v...
stBob by Associate
  • 518 Views
  • 1 replies
Resolved! Typical sensitivity deviation of ISM330DLC
Hi,I saw in the datasheet of ISM330DLC that the sensitivity of accelerometer and gyrsocope can deviate at a maximum of 3%. What would be the typical deviation of the senitivity of accelerometer and gyroscope?Thank you!
KJose.1 by Associate III
  • 519 Views
  • 3 replies
