2025-01-06 12:25 PM
I searched the forum and found out a topic regarding the sensing technology of LIS3MDL sensor. The topic mentioned that LIS3MDL is a TMR sensor, however no support documents are included to further investigate the integrated circuit of the sensor.
Moreover, I found several studies/papers claiming the LIS3MDL is an AMR sensor.
My question is: Is there any official document available regarding the underlying sensing circuit and phenomenon the LIS3MDL sensor is using?
Thank you for your time and support.
2025-01-07 5:34 AM - last edited on 2025-08-10 11:20 PM by Peter BENSCH
