MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Hi, I have the problem that my actual sample rate does not match the sample rate I set. What causes this inconsistency and how can I solve it? Thank you a lot in advance.
I am using the IMU Accelerometer from the sensortile.box with a output data rate of 833Hz together with the RTC(Time) and write the output to the SD card. So I would expect to have 833 samples per second, but I actually get only 775 samples per secon...
CTett.1 by Associate II
  • 2579 Views
  • 6 replies
How can I change the SD card in the sensortile.box?
Hi,I wanted to replace the SD card of the sensortile.box with a faster one, but then I am not able to upload my application. Does anyone know what the problem could be?Thanks in advance and best regards, Carla
  • 1896 Views
  • 7 replies
Details on filtering of Accelerometer
Trying to understand the internal mechanics of the accelerometer I'm using a bit better.Specifically, I'm using a H3LIS331DL.I have settings that will look like this:ODR = 1,000 HzBW = 500 HzFilter = 780 HzHowever, there's not much detail in the data...
DM.10 by Associate
  • 1379 Views
  • 1 replies
About I3G4250D Gyroscopes
 I have some basic questiones about the gyroscopes ic I3G4250Dhow to caculate the SO(sensitivity) and DVoff with current temperature Thow to caculate the rotate speed with current temperature Thow to caculate the temperature value by register OUT_TEM...
Ylin.11 by Associate II
  • 2781 Views
  • 6 replies
How can I resiliently read from FIFO on LSM6DS3/LSM6DSL/LSM6DSM?
I am running on linux and trying to collect accel and gyro samples from the IMU. I have configured the IMU to store data in the FIFO so I can read data periodically without missing any samples.I have tried both FIFO mode and continuous mode but I can...
JRows.1 by Associate
  • 1503 Views
  • 0 replies
SensorTile KIT connection with Unicleo on Windows 11 Fail.
Hi, i am trying to connect the SensorTile kit STEVAL-STLKT01V1 over bluetooth with Unicleo GUI. While I have paired the device with my PC, unicleo is unable to find the device. I can see the device in the selection device section (COM) but all the in...
