MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! ILPS22QS addressing
Hi,In my project, I would like to connect multiple ILPS22QS pressure sensors (from 8 up to 256 units) to a single controller. I saw the dynamic addressing command supported by I3C ENTDAA. However, I also saw the provisional ID is not arbitrary. GETPI...
Jinhao by Associate II
  • 4897 Views
  • 6 replies
  • 4 kudos
Accelerometer calibration
Hi ST team,I would like to know if I need to calibrate my sensor or if you can tell me a method to validate my X, Y and Z outputs.I'm getting the following values in a test but how can I know if my method is correct? I was reading and at the current ...
TVela.1 by Associate III
  • 1672 Views
  • 1 replies
HSDatalog2 problem with STWINBX1
We are using the STEVAL-STWINBX1 at a CNC machine to gather vibration data. We are using the fp-sns-datalog2 HSDatalog Python framework to record the data over USB. Unfortunately, the data seems to always get corrupted in longer measurements (>5 min)...
Resolved! Getting true north with the LIS2MDL and LSM6DSO sensors.
I use LIS2MDL and LSM6DSO sensors (with MotionMC and MotionEC libraries) for getting true north direction. I tested this configuration on IKS01A3 board and it works. But on my custom board, I'm having trouble with getting true north direction. After ...
_legacyfs_online_stmicro_images_0693W00000bl3Z1QAI.png _legacyfs_online_stmicro_images_0693W00000bl3ZBQAY.png
ALT.1 by Associate
  • 2584 Views
Single and double tap on LSM6DSL
Posted on April 20, 2017 at 17:40Hi,I am using the LSM6DSL with a SMT32L476. My question is in relation to the single and double tap generated events (on INT2 pins).1�) When I single tap on the sensor I have an interruption on INT2. If I read TAP_SR...
Omnia . by Associate II
  • 1482 Views
  • 1 replies
  • 1 kudos
