As a complete beginner, how do I program the Sensor Tile STEVAL-STLKT01V1.
OHart.2
I have purchased the STEVAL-STLKT01V1 sensor tile development kit. I have plugged the sensor tile onto the Cradle Expansion board and connected the SWD cable to a Nucleo-F070RB development board. As a complete beginner I am struggling to understand how I am meant to code the sensor tile. Any advice/links on how to use it would be greatly appreciated.
TheLaboz
Hi OHart,
no worries.
We do provide several examples project you can use as starting point to play with and to make some changes to get used to the board.
Once you have acquired more confidence with the board using well prepared examples, you can then start coding with your idea.
here below some projects you can play with as starting point:
https://www.st.com/en/embedded-software/stsw-stlkt01.html
https://www.st.com/en/embedded-software/fp-sns-allmems2.html
