Question about LPS22HH: about POR
TOMY.OKA
I read document AN5209.
This said " VDD must be lower than 0.2 V for at least 10 ms during power-off sequence for correct POR. (3.1 Figure 2)"
If POR did not finish correctly, is there the possibility to be read the un-correct data?
jopuc
Hi @TOMY.OKA​ did you ever get an answer or solved the problem?
TOMY.OKA
Hi, jopuc.
Unfortunately, No one answer this question :^(
