MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! The power consumption of LIS2MDL in power-down mode
Hi,everyone.I measured the power consumption of LIS2MDLTR on the same board in power-down mode.and found that the LIS2MDL chip on STEVAL-MKI217V1(from mouser) consumes less power than the LIS2MDL purchased separately from mouser.We have some question...
young by Associate II
  • 436 Views
  • 3 replies
Resolved! sths34pf80 + lens
Hi!We are working on product that needs to count people on the range of 3-4 meters. We designed dev.board for sths34pf80 and tetsted it with UNICO-GUI. The max range that we are getting is around two meters and therefore it looks that we need to use ...
apallo by Associate
  • 5136 Views
  • 6 replies
Resolved! STEVAL-MKI109D Software-Adjustable Power Circuitry
Hi,I'm trying to write custom firmware for the MKI109D. I am currently using an MKI251A adapter board with it for evaluation. How do I set VDD_DUT and VDDIO_DUT to 3.3V on the MKI109D board without using MEMS Studio?  
Marking of LSM6DSVTR
 LSM6DSVTR is marked V3,Does it change the DC format from YWW to Y or another format? What does "4" mean?Thank you. 
VenusY by Associate
  • 373 Views
  • 3 replies
Lsm6dsv320 fsm interrupt issue
I designed a fsm Design for high G application. The odr of high G and fsm are same. The said functionality is generating interrupt when done on eval kit Nucleo board with iks4a1 kit in Mems studio. But when I converted it into header file and loaded ...
rv_08 by Associate II
  • 272 Views
  • 1 replies
Asm330Lhh datasheet clarifications
Hello, I am currently reading the ASM330LHH May 2020 DocID031239 Rev 4 datasheet and its Chinese version: ASM330LHH: Automotive Inertial Module Digital 3D Accelerometer and Digital 3D Gyroscope User Manual. During the design process, I have a few que...
wz2 by Associate
  • 356 Views
  • 1 replies
LIS3DH and LSM6DSV32X on same SPI bus
Hello,I intend to put LIS3DH and LSM6DSV32X on same SPI bus and use different CS lines to address them separately. But when the CS is desactivated, these components activate their I2C engine, therefore leading to possible conflicts of I2C interface o...
