2025-04-24 2:56 AM
Please , can i use the module STEVAL-MKI228KA (ILPS22QS) with arduino ?
2025-04-24 6:27 AM
Hi @ljm ,
Yes you can.
2025-04-24 6:27 AM
Hi @ljm ,
Yes you can.
2025-04-25 3:24 AM
@ljm wrote:can i use the module STEVAL-MKI228KA (ILPS22QS) with arduino ?
Of course you can: the sensor neither knows nor cares what microcontroller or software framework you use - all it needs to see is valid signals at its pins.
The only thing to beware of would be voltage levels - are you using a 5V or 3V Arduino?
