MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Do these IIS2DLPC XYZ output values look correct?
Hello, I apologize in advance for my long post, and ignorance when it comes to interpreting this linear accelerometer data. The only one I have used in the past gave me euler angles, and I had no problem calculating tilt from them. I am trying to per...
IIS3DHHC. MSL3 preconditioning.
What exactly "MSL3 preconditioning" means?Does it mean the same as "baking"?This preconditioning corresponds with soldering, or all the time?How accuracy are affected by moisture?I understand that omitting the baking before soldering, will cause crac...
STSW-MKI109W firmware upgrade
I had an error // not supported by motherboard // when connect STEVAL-MKI197V1 to UNICO like the image error.png attached.I reinstalled STM32 drivers, reinstalled UNICO,... but could not solve the problem.Then I upgrade firmware by command line in U...
Tam Tran by Associate II
  • 1747 Views
  • 0 replies
Self test mode in LIS2DH12TR
Hello Team,We want to test self-test mode in LIS2DH12TR.We have followed below application note:https://www.st.com/content/ccc/resource/technical/document/application_note/group0/55/ef/e4/9f/d1/e9/46/2c/DM00365457/files/DM00365457.pdf/jcr:content/tra...
