MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Issues with LSM6DSO Gyroscope Data
As we are verifying the Gyroscope data output of the LSM6DSO, we noticed the value goes to -3.311157 randomly.Below table is an example of the issue.We are rotating the device at a constant speed and expected the value to be around 35, but all of a s...
KShah.2 by Associate
  • 1139 Views
  • 1 replies
Resolved! Influence of magnetic fields in MEMS accelerometers
Good morning,I would like to know if measurements of MEMS accelerometers/inclinomteres are influenced by near static magnetic fields.The question is generic but regards particularly the model IIS2ICLX.Thanks for the attention.
Guille by Associate II
  • 3930 Views
  • 3 replies
LIS2DH12 FIFO after interrupt.
Dear community,i have one more problem with my lis2dh12 project.So my sensor run in STREAM-TO-FIFO mode.After init. i can interrupt my sensor und get the right data.After some time my uC go into sleepMode (deinit i2c bus).When i trigger my lis2dh12 a...
TGeld.1 by Associate
  • 1302 Views
  • 1 replies
SMD footprint recommendation for LIS2DH12
I need to understand what is the right SMD footprint recommendation for LIS2DH12.Recommendations in TN0018 SMD guideline AN , ultra librarian recommended land pattern and footprint actually used in DIL24 adapter significantly differ from each other. ...
MFish.1 by Associate
  • 1875 Views
  • 1 replies
Lsm6dso : how to get accelerometer data in FIFO
I'm working with lsm6dso for activity monitoring project. I want to record the acc and gyro data in the fifo and trigger an interrupt when the number of samples in fifo are more than the configured watermark. I already achieved to get the gyro data i...
ADvor.2 by Associate II
  • 3452 Views
  • 4 replies
LIS2DH12 STREAM-TO-FIFO reset
Hello,i have a problem with my lis2dh12 acc sensor.I use the sensor in low power, 8bit with 100Hz and STREAM-TO-FIFO mode.After a interrupt, i read out all 32 FIFO reg and the INT1_SRC reg. These value look good. But when i trigger the interrupt agai...
  • 1046 Views
  • 1 replies
