MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
MP23DB02MM Frequency Range
I interested in the higher frequency range of this device. The datasheet states clearly the LF cutoff at 35Hz, but there is no real discussion on the HF end apart from the characteristic graphs stopping at 10KHz. The device can be clocked up to 3.3MH...
JKing.3 by Associate II
  • 2842 Views
  • 5 replies
Resolved! SensorTile.box PRO Expert Mode logging both Gyroscope and Microphone
Hi! I am using the SensorTile.box PRO in Expert Mode and try to log both Gyroscope and Microphone on the SD Card. When I try to upload the App I receive this error message: "There was a timeout error loading the App on the board". If I make an App to...
Gerva by Associate II
  • 1650 Views
  • 1 replies
Resolved! LSM6DSO master I2C pull up resistors
Hi @Eleon BORLINI, I am trying to build a custom 9 dof imu using LSM6DSO and LIS3MDL in mode 2, according to LSM6DSO datasheet.I found this page on AN5192 about sensor mode 2 (pg. 63). i2c master would be LSM6DSO and i2c slave would be LIS3MDL in thi...
el659 by Associate III
  • 1523 Views
  • 1 replies
  • 1 kudos
Resolved! A problem about ASM330LHB safety lib
Hello,     I have applied for the ASM330LHBxx ASIL B library from ST's web, and integrated it to my program, all the functions worked fine. But the noise of GYRO has gone beyond our requirement, we used to enable the LPF in ASM330 to lower the noise....
ssdgf by Associate
  • 3069 Views
  • 3 replies
LPS28DFW arduino
Hello,Actually i'm trying to mesure the pressure using LPS28DFW and arduino uno, but i have some problems, the i2c communication does not working.Can help me please and thank you.arduino code : #include <Wire.h>#include "SparkFun_LPS28DFW_Arduino_Lib...
ljm by Associate III
  • 2033 Views
orientation and movement values in LIS2DW12 accelerometer
Hello We are working with accelerometer LIS2DW12.we did tests on the different movements of the accelerometer and the graphs we see (the graphs were made with the x_physical y_physical z_physical values). However we see graphs that are not as we expe...
0693W00000BbSy9QAF.jpg 0693W00000BbT1GQAV.jpg 0693W00000BbT2OQAV.jpg 0693W00000BbT2iQAF.jpg
Msaga.1 by Associate II
  • 8059 Views
  • 25 replies
LSM6DSO32 Pedometer
Hi,I designed a special board that includes the LSM6DSO32 sensor. I can get gyro and accelometer data from this sensor correctly. But even though I enable the pedometer output in the embedded function part of the datasheet, I can't get it. Can you he...
Buse by Associate II
  • 3716 Views
  • 7 replies
  • 2 kudos
The STTS22 temperature sensor gives me back 0 °C
I am reporting below a post created in March 2023 because I did not receive any response. Hello everyone,after some time that I use the sensor, it gives me back a temperature value of 0 °C.I'm using a library taken from github that I adapted to work ...
SSerg.4 by Associate III
  • 3947 Views
  • 4 replies
LIS2DH12TR have some questions for help .
  LIS2DH12TR   have  some questions for help below: 1. The captured accelerometer data found that there was a fixed frequency of jitter, and I wanted the manufacturer to determine whether it was a problem with the hardware itself2. I would like to as...
