Please advice source code have to use STHS34PF80.
Nakorn
Eleon BORLINI
Hi @Nakorn​ ,
Please consider that the STHS34PF80 device is currently in "evaluation" status (and even the online datasheet does not report the device registers and parameters). When it will be officially released, the drivers will be uploaded on Github.
-> GitHub - STMicroelectronics/STMems_Standard_C_drivers
-Eleon
Eleon BORLINI
Hi @Nakorn​ ,
-Eleon
Hi @Eleon BORLINI ,
I'm planning on using the STHS34PF80 for measuring the Object temperature. I wasn't able to get any information about its max object temperature rating. Is it as same as the the max storage temperature, if not so can you please let me know about the same.
