STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1406 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 556 Views
  • 0 replies
Compile problems because of linked resources
I update to V1.16 and found, that my project cannot compile anymore.Problem are compile errors, double definitions and so on. I did not change the code, just updated and regenerated everything include the code generation of CubeMX ( from within the i...
SThie.1 by Associate II
  • 1425 Views
  • 1 replies
STMCube32 IDE - license terms not readable
When installing for example the Nx_MQTT example for B-U585IOT02A you need accept a license for CubeFW U5 1.6.0. You are supposed to view it 1st. However, at least with Ubuntu 22.04 and FireFox as default browser (default for Ubuntu 22.04) you can't v...
STM32Cube ID 1.16.0 - uninstall.sh missing?
I have been asked to remove (uninstall) the STM32Cube IDE and replace it with another version. However, the instructions found how to uinstall STM32Cube IDE suggest there should be an uninstall.sh script in the /opt/st/STM32CubeIDE_<version> -folder....
Resolved! (M24M01E-F) Data storage
Hi,For my project, I am using an M24M01E-F I2C EEPROM. In this application need to store sensors offset values (float data type) in EEPROM. whether it can be able to write/ read float value. Regards,Rishvana M
Rishvana by Associate II
  • 1468 Views
  • 1 kudos
Broken server install / Debian 12.5 Bookworm
Hi,Recently, when I tried to install the Debian Linux version of STM32CubeF4 on my Debian Linux (v12.5) Bookworm system, I began by trying to install a package that included Server 2 in its name. The server install hung at 50% installed. Each time I ...
How can I change the build analyzer color preferences?
I use the dark theme of the IDE and can find no preference settings to change the colors for the build analyzer output. The IDE shows the usage info with light gray text on a bright green background which (to my eyes) is almost unreadable. I say almo...
DSudo.2 by Associate III
  • 1397 Views
  • 1 replies
