STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1432 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 560 Views
  • 0 replies
Debug Start Up Script Comments and Variables
Dear allI moved from Atollic to Cube IDE.To debug a firmware without boot loader I use the Run Commands (located in the Debug Configuration -> Startup Tap) to move the $pc (program counter) to the desired address, where the firmware actually starts. ...
Extending example projects in the IDE
I'm new to IDE's (i'm old school, all my dev has been done with unix command line, shells, manually created make files), so my apologies up front for what is probably a pretty basic question. I'm starting with the example SBSFU KMS for the B-L475E-...
SBade.1 by Associate II
  • 1899 Views
  • 3 replies
BLE_Beacon Example on STM32CubeIDE and P-Nucleo WB55
I'm trying to make the "BLE_Beacon" example found inside the "STM32CubeWB" file work with the STM32CubeIDE and the P-NUCLEO WB55 board. The program compiles correctly but I can't see the beacons. Debugging I saw that when it arrives in the loop it cr...
MVegl.1 by Associate
  • 2583 Views
  • 4 replies
I have STM32CubeIDE version 1.1.0 on a MacBook, and when I run it it says updates to 1.2.1 are available. Doesn't upgrade and gives following error message, and now seems broken - ie it wont import my project.
An error occurred while collecting items to be installed session context was:(profile=STM32CubeIDE, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=). No repository found containing: osgi.bundle,org.eclipse.epp.mpc.core,...
Debugger unable to start in STM32CUBE IDE throws the Error 193 ?
Hello all STM32 Lovers,I am developing a project in STM32CUBE IDE 1.2.0 for my old STM32VL Discovery Board(STM32F100RBTX) that is connected to the old Nokia LCD everything is working perfectly fine (code generation, compiling, building) but I don't k...
Shri by Associate II
  • 2490 Views
  • 3 replies
