MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
[LSM303AGR] The compass does not work.
The LSM303AGR chip is used in Android device. I use STMems_Android_Sensor_HAL_Input sensor HAL from https://www.st.com/content/st_com/en/products/embedded-software/mems-and-sensors-software/drivers-for-mems/androidhalinput.html.The magnetometer works...
Weird Range reading delay with VL53L1X
Hello,I am looking to scan a 2D surface with the ROI feature of the VL53L1X. I have been following the doc UM2555 and using the Polulu ST API but I can't get it working properly. The wall is at 1.6m and the object at 48 cm. The precision is not the i...
PChat.1 by Associate II
  • 2286 Views
  • 4 replies
IIS2DH axis Y not working
Hello,i use iis2dh (STEVAL-MKI168V1) on Arduino Due through spi.unfortunately, the y axis does not respond (I tried 3 development boards!).if instead use STEVAL-MKI135V1 board the same firmware works.could someone help me?best regards,Francesco
FItal by Associate II
  • 2430 Views
  • 4 replies
LIS3DHTR - Is vapor phase soldering possible?
Hello, I would like to know if it is possible to solder the LIS3DHTR sensor with the vapor phase soldering process. I still checked the TN0018 document but couldn't find any hint.Thank you!
CPuru.1 by Associate
  • 816 Views
  • 1 replies
  • 1 kudos
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
