2019-08-14 12:35 AM
I want higher data rate for magnetometer from LSM9DS1, specifically 100Hz.
I found 'FAST_ODR' option in CTRL_REG1_M register but couldn't find any details such as side-effects or maximum ODR.
Where can I find documents for the FAST_ODR? Or is it just in experimental stage? Is it ok to enable FAST_ODR to get data rate 100Hz?
2019-08-31 4:37 PM
There is another answer in the forum. Maybe it's what you are loking for: https://community.st.com/s/question/0D50X00009XkYNMSA3/lsm9ds1-data-sheet-says-that-the-fastodr-mode-enables-magnetometer-data-rates-higher-than-80hz-how-do-we-specify-this-data-rate
