MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
[lsm303agr] How to get temperature sensor value correctly?
It is always 0 to get the value of OUT_TEMP_L_A (0Ch), OUT_TEMP_H_A (0Dh).Before reading OUT_TEMP_L_A (0Ch), OUT_TEMP_H_A (0Dh), check the values of TEMP_CFG_REG_A (1Fh), CTRL_REG4_A (23h) and STATUS_REG_AUX_A (07h) as bellow:TEMP_CFG_REG_A (1Fh): 0x...
Resolved! STMicro's Unicleo-GUI PC Application breaks when connecting through STMicro's ST-LINK in-circuit debugger and programmer pod. Why? [SOLVED]
Hi,I have used the STMicro's Unicleo-GUI PC Application to test both the LSM9DS1 STMicro's HAL and STMicro's Compass Middle Ware (from X-CUBE-MEMS1) - and - the LSM6DSO-LIS2MDL combination using almost the same software. All STMicro code (HAL for th...
Rstua.1 by Senior
  • 3012 Views
  • 8 replies
LPS22HH not responding to pressure changes
I'm testing the LPS22HH on the MKI192-V1 eval board. At normal atmospheric pressure it reports about 1013 hPa, which is what I expect, and it fluctuates over time by a few hPa. It also reports a reasonable temperature value, so I know the I2C interfa...
TFras.1 by Associate
  • 964 Views
  • 0 replies
Gyro & Accelerometer Linearity Specs for ISM330DHCX and LSM6DSM
I'm working on selecting between ISM330DHCX and LSM6DSM for some products under development. The one key sensor specification I can't find the data sheets is Typical Gyro/Accelerometer Nonlinearity (Best-fit straight Line) (% of FS). Can anyone poi...
SLibe by Associate II
  • 1984 Views
  • 3 replies
How to perform a factory reset for SensorTile?
Hi Is there a way to perform a factory reset for SensorTile? For some reason, my laptop can't detect it anymore. Device manager said "This device cannot start. (Code 10). A device which does not exist was specified." I try to erase full chip flash me...
DWang by Associate II
  • 10434 Views
  • 31 replies
LIS2DE12 , cant read x,y,z values
hi,i'm trying to read x,y,z values using FIFO - LIS2DE12_FIFO_READ_STARTbut every time get zero in all the answers, also try to read separately x,y,zin the address LIS2DE12_OUT_X_H,LIS2DE12_OUT_Y_H,LIS2DE12_OUT_Z_Hin this mode I'm getting values but ...
M4D by Associate II
  • 1085 Views
  • 1 replies
