MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
SPI interface simulator
Dear All,I'm developing and IC which needs to interface with the ISM303DAC device. I'd like to simulate the SPI interface of the ISM303DAC  with my custom IC to verify correct timing of the signals and device behavior. I'm looking for a simulation mo...
PVis.1 by Associate
  • 1469 Views
  • 1 replies
Resolved! Is someone using the LSM6DSL with SPI using BSP Custom driver?
Hi everyone, I'm using an STM32L4 microcontroller and a LSM6DSL MEMS. They are conected with the spi2 interface and for configuring everithing I'm using STMCubeIDE.I'm able to use the MEMS without BSP Custom, but when I try to set the BSP, it doesn't...
Gabriele1 by Associate II
  • 2106 Views
  • 1 kudos
I have order x-Nucleo-531L1A2 and got the board, now I found the document(UM2759) description is different with my board. such as there is white "Display" text on board from doucment, but my board hasn't this "Display" text.
I have order x-Nucleo-531L1A2 and got the board, now I found the document(UM2759) description is different with my board. such as there is white "Display" text on board from doucment, but my board hasn't this "Display" text, same time some unit also ...
Roger LI by Associate II
  • 1411 Views
Is the LSM9D an active product?
Hello.I am trying to develop a product using LSM9D.By the way, neither Mouser nor Digi-Key are out of stock.The lead time was 44 weeks. Is it correct that the product is being produced?Thank you.
DLEE.1 by Associate
  • 1876 Views
Sensorfusion
Hello , Can some one please post the link to sensor fuson librares for linux platform.(gcc compiled i guess) with some documentation to use.Most of th elinks I found is for iNemo (controller side)I want to use it for raspberry PI Thanks,
darla14 by Senior
  • 1042 Views
  • 1 replies
Resolved! FP-IND-PREDMNT1 amplitude value of the FFT
I would like to know how is the amplitude of the FFT calculated by the FP-IND-PREDMNT1 firmware related to the acceleration measured by the accelerometer found on the STEVAL-STWINKT1 board. It is expressed in an absolute value but I need to know the ...
ABent.1 by Associate II
  • 2233 Views
  • 4 replies
Hello ST community Experts , MEMS mic + STM32f4xx evaluation board I am trying to stream PCM data serially on UART . Some issues please help?
Configurations :- STM32CubeMX M4-F446RE+ICS43432 micsysclk-168MHz HSE, DMA- circular,SPI2_RX ,half wordI2S2 - half duplex ,master receive mode 32KHz audio frequency USART2 - 9600 B/sPDM2PCM middleware use for conversion..1)Can Anyone suggest is there...
SG.4 by Associate II
  • 2565 Views
  • 7 replies
