MotionFX hard fault
‎2018-02-27 10:26 PM
I'm trying to implement MotionFX in my application. So far I have a very basic setup which executes correctly.
MotionFX_initialize();
MotionFX_GetLibVersion(ver);
printu(ver, 1);
MotionFX_getKnobs(&iKnobs);
iKnobs.output_type = MFX_ENGINE_OUTPUT_ENU;
iKnobs.LMode = 1;
iKnobs.modx = 1;
MotionFX_setKnobs(&iKnobs);
MotionFX_enable_6X(MFX_ENGINE_DISABLE);
MotionFX_enable_9X(MFX_ENGINE_ENABLE);�?�?�?�?�?�?�?�?�?�?
Then, in a thread, I pull data out of my sensors and push it to the motionfx:
MFX_input_t data_in;
MFX_output_t data_out;
data_in.acc[0] = mptr->acc.AXIS_X * FROM_MG_TO_G;
data_in.acc[1] = mptr->acc.AXIS_Y * FROM_MG_TO_G;
data_in.acc[2] = mptr->acc.AXIS_Z * FROM_MG_TO_G;
data_in.gyro[0] = mptr->gyro.AXIS_X * FROM_MDPS_TO_DPS;
data_in.gyro[1] = mptr->gyro.AXIS_Y * FROM_MDPS_TO_DPS;
data_in.gyro[2] = mptr->gyro.AXIS_Z * FROM_MDPS_TO_DPS;
data_in.mag[0] = mptr->mag.AXIS_X * FROM_MGAUSS_TO_UT50;
data_in.mag[1] = mptr->mag.AXIS_Y * FROM_MGAUSS_TO_UT50;
data_in.mag[2] = mptr->mag.AXIS_Z * FROM_MGAUSS_TO_UT50;
MotionFX_propagate(&data_out, &data_in, 0.01);
MotionFX_update(&data_out, &data_in, 0.01, NULL);�?�?�?�?�?�?�?�?�?�?�?�?�?
For now, the 0.01 deltatime variable is not accurate, but will becorrected later.
The problem is that I can not call the _propagate and _update function. If I leave only _propagate, I can call that function ripediatelly and get some results. Same with _update. However, if I call them both with each iteration, I run into a hard fault every time.
I have increased stack size to 0x6000 in .ld file with the same results.
In my debugging, it seems that the two functions run fine outside of the thread context.
‎2018-02-27 11:40 PM
I resolved my problem as I was writing the question... I kept increasing the stack size of the application in the ld file, but not of the thread itself. That was the problem.
‎2018-02-27 10:34 PM
I use Keil IDE and try to follow the document:
http://www.keil.com/appnotes/files/apnt209.pdf
I start from the stack size checking, especially when I have a lot of local variables with big sizes like arrays inside functions.
I check if I refer to existent memory areas when reading / writing directly from / to RAM (also SDRAM if controlled by FSMC or FMC)
‎2018-02-27 11:48 PM
I like talking to someone to explain the issue and many times during the conversation I have an answer. I heard from a professor of MIT in Computer Science area that this is very good method of approaching / attacking problems.
It works for me and my friends in my engineering department.
‎2018-09-30 5:20 AM
I have the same issue with ARM and STM32L031K6 and the MCU gets HardFault after the call of motionFx_CM0P_Initialize().
My stack size is 0x1000 (already 4k) and it should be enough. I think, the problem is something else and need some help
‎2018-10-01 1:11 AM
@drozel​ did you enable the clock for CRC unit?
The CRC is needed for library initialization.
‎2018-10-02 3:00 PM
@Miroslav BATEK​ yes, i've already found it after diassembly of the library code:>
but thank you for the fast answer!
‎2019-01-03 11:48 PM
Hello!
I have the same problem!!!
I used the nucleo-F103RB board and works fine. But, when I change to my board (with STM32F103RG) the MCU gets HardFault when execute 2 time MotionFX_propagate and after, MotionFX_update.
It's the same code changing the microcontroller definition and the .ld.
I was created the proyect with the cubeMX.
‎2019-01-04 3:35 AM
did you initialize CRC module?
you could also debug the library in assembler and find out the instruction causes hardFault. So i found my problem with CRC.
‎2019-01-04 3:52 AM
Thank you Dozel!!
Yes!! with the 103RB the program is working, but if I change to the 103RG (same family, same package but with more memory) it crash!
I'm using Atollic and I can't see the disasembly... It is protected
