MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
IIS3DWBTR Filter LPF2 frecuency response
Hello Community,We have been using the IIS3DWBTR sensor for some time and have observed some odd behavior regarding filters. We recently performed some experimental tests on the LPF2 Filter to corroborate the frequency response curves on page 20 of t...
0693W00000KZwDXQA1.png 0693W00000KZwDDQA1.png 0693W00000KZwEaQAL.png 0693W00000KZwFEQA1.png
MSierraA by Associate II
  • 2164 Views
  • 3 replies
Resolved! Question about SAI configuration with a MEMS microphone
I want to connect a MEMS microphone to my stm32 using its SAI interface. I found a document called "Interfacing PDM digital microphones using STM32 MCUs and MPUs" which gives some examples about how to do it.My question is about the configuration :Wh...
EEnco.1 by Associate III
  • 2620 Views
Resolved! Unable to convert PDM data to PCM data using pdm2pcm
I'm using a stm32wb55RG. I'm trying to get data from a MEMS PDM microphone and convert it into PCM data. I'm using SAI PDM interface and DMA. So far, I think I manage to receive the PDM data (I get some values from the SAI interface) :I don't know if...
  • 3399 Views
  • 3 replies
「LIS2DU12�?3軸加速度センサー�?�アプリケーションを確�?�?��?��?��?��?�。 �?��?��?気圧センサー�?�連�?��?��?�階段昇�?を確�?�?�る�?��?��?��?�能�?��?�ょ�?��?�?
�?�世話�?��?�り�?��?�。トリニティ株�?会社�?�張�?�申�?��?��?�。弊社�?�ウェアラブルデ�?イス用�?�加速度センサーを購入�?�る予定�?��?�り�?��?��?��?貴社�?�「LIS2DU12�?3軸加速度センサーを�?�定�?��?��??�?��?�?�定�?�る�?�?�。該当センサー�?�アプリケーションを確�?�?��?��?��?��?�。計測�?��??る詳細データを教�?��?�頂�?�る幸�?��?��?�。例�?��?�:歩数�?ランニン...
MZhan.6 by Associate
  • 882 Views
  • 1 replies
1. Does the MotionDI library output the gravitational acceleration along with linear acceleration as I am getting it in the lin acc. data? 2. How to wipe out the effect of gravitational acceleration in linear acceleration? Sensortile kit is used.
Sensortile kit is used and linear acceleration is fused output from gyroscope and accelerometer,the sensor is kept with z-axis of accelerometer being parallel to gravity (screenshot attached).
MAhm.1 by Associate
  • 1736 Views
  • 1 replies
LSM6DSM on SensorTile using SPI?
I would like to know what I am doing wrong or what register setting on the LSM6DSM that I missed setting?Using a sensorTile (STM32L476JG) that is connected to LSM6DSM. APB1 Clk = 16MHz.My settings are : My code is trying to read WHO_AM_I register on...
SWenn.1 by Senior III
  • 3215 Views
  • 7 replies
