MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! suggested land pattern for Part no:LSM6DSLTR
We have used your one component in our project but we are facing some issues in designing the footprint because we didn't get the suggested land pattern in the Datasheet.So kindly share with us the suggested land pattern for Part no.LSM6DSLTR mention...
TShah.1 by Associate
  • 1795 Views
  • 3 replies
Resolved! LSM6DSO32 calibration
Hello,I made a special card design that includes LSM6DSO32. I want to use this sensor in motion classification project. I want to ask a question about a subject that is said by everyone but I do not know. Everyone has mentioned that it is necessary t...
Buse by Associate II
  • 2926 Views
  • 4 replies
  • 1 kudos
Resolved! ISM330DLC Drift Problem
Hi all, I was wondering if anyone here has worked with the ISM330DLC IMU and was able to get positional displacement from it? I am trying to do this for one of my projects, but have run into drift issue. Any help is most appreciated! Thanks!Thank you...
IKalh.1 by Associate II
  • 2108 Views
  • 5 replies
LIS2DE12 sensor configuration is unclear
Hello,I'm testing LIS2DE12 accelerometer, trying to communicate with it through I2C. I want to make an interrupt on INT1 when some larger value is present (sensor is being shaken for example). I configured Interrupt to work on Or mode and for startin...
DSimp.1 by Associate III
  • 1021 Views
  • 1 replies
LPS22HB gives inconsistent readings
Please refer this thread. I don't think that the sensor can get damaged in such short period of time. Is it possibly due to moisture? At times I get 1018hPa which is even higher than sea level pressure of 1013.5 hPaPls help.
DGand.2 by Associate
  • 995 Views
  • 1 replies
LIS3DH读�?�FIFO为空 LIS3DH reads FIFO as empty
设置 ODR400HZ�?范围 2g�?�?�用 FIFO 并�?置�?模�?。读�?��?个寄存器的�?置没有问题。数�?��? 5 毫秒读�?�一次,FIFO �? time_ src=0x20 读�?�一次。
jzhon.3 by Associate
  • 757 Views
  • 1 replies
