MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! TARIC code and EOL details required for ASM330LHHTR
Hi,We are using ASM330LHHTR in our design. Could you please share the TARIC code details for this particular component? Additionally, could you provide the information on the End-of-Life status of this part?Regards,Sowmiya
Sa.11 by Associate II
  • 3076 Views
  • 3 replies
  • 1 kudos
LSM9DS1 SDO always 0
Hey folks,I've fabricated a little PCB to glue an LSM9DS1 to an ESP32-S3. As far as I can see, the ESP32 is sending the correct signals but the LSM9DS1 isn't returning anything useful. Here's what I get when I try to read 0x0F, the WHOAMI register, f...
SDS00014.png Untitled.jpg SCH_Adafruit LSM9DS1 Rev A_1_1-Adafruit LSM9DS1 Rev A_1_2023-12-02.png
STHS34PF80 IR Sensor Performance in Continuous Mode
Hello,We are currently in the process of developing firmware for a device that contains the STHS34PF80 IR Sensor.At present, we have decided to use the continuous mode of this sensor, and we would like to seek clarification on its behavior under cert...
KD2 by Associate II
  • 8563 Views
  • 7 replies
send motion sensor data via BLE with STEVAL-STWINKT1B
Hello!I am trying to create a program where I send motion sensor's data via BLE using evaluation board STEVAL-STWINKT1B. For that, I have used as a guide the firmware example on the board's website (https://www.st.com/en/embedded-software/stsw-stwink...
aag by Associate II
  • 3234 Views
  • 3 replies
LSM6DSV SFLP 是否支持9轴融合?
我们现在正在调研LSM6DSV,确定他的SFLP支持6轴融合并可以正常输出四元数。我们想知道他是否支持9轴融合(+磁力传感器)?如果支持如何实现?
Yansu by Associate III
  • 1992 Views
  • 1 kudos
Log not stored in STEVAL-MKBOXPRO 's SD card.
Hi team,I used algo builder(Version 3.2.0.4544) and tried to store ACC ,Gyro and other sensor values in SD card. I can see the sensor values in User Messages window(Unicleo GUI), but that data not stored in SD card. Kindly help to store the data in S...
Daya by Associate II
  • 1545 Views
  • 1 replies
How to get 6DOF from STVAL-MKBOXPRO
Hi all,                               Can we get 6DOF(Acc + Gyro only) quaternion (Game Rotation Vector) data from STVAL-MKBOXPRO?. Is there any example available? kindly share the link.
  • 1220 Views
  • 1 replies
Resolved! Lenses for STHS34PF80 IR Sensor
Hello,We are currently in the process of developing a device that contains the STHS34PF80 IR sensor. After study of the datasheet and conducting our own tests, we have found that the sensor reliably detects a person within a 4-meter range. However, f...
KD2 by Associate II
  • 1940 Views
  • 1 replies
