MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! LSM6DSL Interrupt Generation -- Interrupts constantly fire
I'm trying to get the Activity/Inactivity interrupt generation on the LSM6DSL working. I've implemented the example code in the data sheet below. I'm using an stm32L475.However, this interrupt fires constantly, regardless of either the sleep duration...
EBurnsy by Associate
  • 2511 Views
iNEMO IMU part number for SE marking
Hello, can anyone please tell me the part number for a device marking with "SE"?  I attached a photograph. Our BOM specifies ST IMU iNEMO parts LSM6DS3TR-C and LSM6DSLTR.   The part marked with "SE" is not working like other parts marked with "SH" on...
bricroft by Associate
  • 2254 Views
Resolved! Difference between ISM330 and ASM330
Hello All,I am trying to decide between these two components and looking at the datasheet they seem pretty identical. Are the sensing elements the same? what is the difference between these two families? Also, looking at the ASM330* there are many ve...
Resolved! LSM6DSL partially failling self-tests
Hello everyone, I am currently trying to use a LSM6DSL (accelerometer and gyroscope) but only the accelerometer works. I am using a NUCLEO-L476RG with a LSM6DSL from a STEVAL-MKI178V2 with the st library : lsm6dsl.c/h and lsm6dsl_reg.c/hAfter the ini...
SMari.10 by Associate II
  • 2780 Views
  • 1 replies
ASM330 4D orientation/tilt interrupt issues
The ASM330 does not generate correct 4D tilt/orientation interrupt at higher rotational speeds of 200 RPMIt is configured for 4D Tilt detection with highest ODR and highest RangeIs there any rotational speed limit beyond which 4D orientation will not...
kvijay by Associate
  • 2333 Views
  • 1 replies
