MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! Regarding motion FX library
Hello Everyone,I am using ISM330DLC and able to read X,Y,Z and motion FX library in my application (Gyroscope) to get Eluer angle's and here is my doubt that before giving the senor raw data to the FX library, we supposed to do the gyroscope calibra...
Anil3 by Associate III
  • 1833 Views
  • 3 replies
MotionFX library and MotionMC
Hi, I'm using MotionFX library v3.0.0, even if i do compass calibration, yaw value is still drifting some times. do I need to use MotionMC library to get better results?
LIS2DW12 latched mode
Hi Experts,I am using lis2dw12 accelerometer connected to esp32s3 and recently have got a situation which is blocking for esp32s3 to read status registers of accelerometer when LIR =1 (latched mode). I put accelerometer on stationary  mode and routin...
farshad by Associate II
  • 4352 Views
  • 10 replies
Resolved! How to read FIFO of LIS2DW12
GreetingsI am trying to read from the FIFO of the LIS2DW12. What confuses me, is that reading through the datasheet, there are only registers which indicate the number of unread samples in the FIFO (FIFO_SAMPLES (2Fh)), and a control register FIFO_CT...
ZAIDS-S23 by Associate III
  • 4184 Views
  • 5 replies
LSM6DS3 FIFO Status/FTH for Continuous to FIFO
I am trying to configure a LSM6DS3 to capture Tap events in the FIFO similar to how Unico does. i.e. I press "Continuous to FIFO" button (to enable a new capture), then tap the sensor, and the acceleration of the tap event appears on the screen (afte...
SS13 by Associate II
  • 4845 Views
  • 7 replies
Resolved! Difference between IIS3DWB vibration sensor and ISM330DLC?
Hi,I want to know the difference between IIS3DWB and ISM330DLC.Why we are calling IIS3DWB as vibration sensor while ISM330DLC has accelerometer inside with the same specifications as in IIS3DWB? Which is better in monitoring the vibration in motors?T...
RJain.1 by Associate III
  • 2172 Views
  • 4 replies
