STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1440 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 564 Views
  • 0 replies
logging into myST
Hi there,I am having some trouble logging into myST. Every time I try, I either get the same prompt or nothing happens, and i am unable to log in (image below). Is there a Solution to this
yz by Associate
  • 882 Views
  • 1 replies
RC Receiver input not being picked up
 This is the code i am using to pick up input from RC receiver to then change pwm values, but there seems to be a problem. PWM's are unresponsive to RC receiver which is connected to timer 2 channels. Is the given code correct? could it be that HAL_D...
Sonzaye by Associate
  • 797 Views
Communicate NUCLEO-G070RB USART with SPI as MSB
Thank you always for your hard work,I needed 4 SPIs, so while exploring the board, I found a text that could make USART work like SPI, so I tried this with the NUCLEO-G070RB.The example I referenced is "USART_SyncCommunication_FullDuplex_DMA_Init" on...
yurim by Associate II
  • 2307 Views
  • 6 replies
  • 6 kudos
How to configure STM32CubeIDE to support C++ development?
1. How to configure the IDE to use g++ compiler to compile all the files includes "*.c" files in the project? Current it compiles the .c files by using gcc and .cpp by using g++ ...​2. If I rename main.c to main.cpp, the cube code generator will crea...
TLeaf by Associate II
  • 54429 Views
  • 55 replies
  • 10 kudos
Resolved! A problem with '-fcyclomatic-complexity'
I'm using kali linux and the latest version of arm gcc available on arm website and the latest CubeIDE. When I first set everything up everything was working fine, but then I created an empty project for another MCU(STM32 G030F6P6) and got the follow...
rambo by Associate
  • 8100 Views
  • 5 replies
  • 5 kudos
Resolved! STM32-L4A6 with OV5640
Hello Community!I am a newcomer to STM and am currently trying to control the OV5640 with the STM32-L4A6 (NUCLEO-L4A6ZG).Unfortunately I have no success and cannot establish communication. I am biting my teeth out and am in urgent need of support. I ...
nicola3 by Associate II
  • 16717 Views
  • 10 replies
remote OpenOCD debugging, Could not verify ST device!
i already did this in 2021 https://community.st.com/t5/stm32-mcus-products/openocd-not-reseting-my-chip/td-p/192537Is there a chance ST implemented new anticlone stm32 chips in new cubeIDE versions? and noone told OpenOCD about it?Using CUBEIDE 1.16....
Javier1 by Principal
  • 1897 Views
  • 3 replies
