MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
LIS2DE12 temperature conversion
We have an LIS2DE12 accessed via i2c. We set:0x20 to 0x1f0x1f to 0xc00x23 to 0x80Then we read 0x07 until TDA is set.Finally, we read temperature data.Example 1:0x0c = 0x000x0d = 0x13Example 2:0x0c = 0x800x0d = 0xdfHow do we convert these values to d...
JPerr by Associate
  • 792 Views
  • 1 replies
gyroscope calibration library for linux
Hi,We are using gyroscope calibration library for linux in order to get more accurate gyroscope values. Can u please tell me what value need to be set for the various parameters in the iNemoEngine_gbias_setKnobs() API .Thank you,Best Regards,Sharmi...
shammi d by Associate II
  • 1049 Views
Reading data from H3LIS331DL
I was wondering about the format of the data from the H3LIS331DL accelerometer. At +/-400 scaling, 0.195 is listed as the scaling factor (in G). However, the data appears to be only 12-bit, left justified, since the lower 4 bits are always zero. Afte...
MMacL.9 by Associate
  • 1095 Views
  • 1 replies
LSM6DS3 Continuous FIFO interrupts
Posted on July 03, 2018 at 03:35LSM6DS3 Continuous FIFO interruptsFor this discussion 1 sample = 6 bytes of 3d accelerometer data.I want to use FIFO to save power on CPU.As long as all sample data fits in the FIFO, all is straight-forward.I'm unable...
VL53L0X platform port is too broad
Porting the VL53L0X API (https://my.st.com/content/my_st_com/en/products/embedded-software/proximity-sensors-software/stsw-img005.license=1533144599665.html) to a particular platform requires implementation of a set of functions abstracting I2C acces...
The microphone used on the bluecoin (MP34DB04) is not commercialed any more can you recommend us same replacement component?
Hello,We are developing a board for sound processing based on the the bluecoin(STEVAL-BCNKT01V1) demo board, we have several questions concerning the way we can implement this technology on our board. On the board we develop we want to test stereo so...
IHich by Associate
  • 843 Views
  • 1 replies
VL53L0X
Posted on July 12, 2018 at 06:09今ã€�RUNNESAS製R5F100FCを使ã�£ã�¦VL53L0Xã�‹ã‚‰è·�離データをå�–å¾—ã�—よã�†ã�¨ã�—ã�¦ã�„ã�¾ã�™ã€‚ã�§ã�™ã�Œãƒ‡ãƒ¼ã‚¿ã‚·ãƒ¼ãƒˆã‚’見るã�¨å�„レジスタ情報ã�Œã�ªã��å›°ã�£ã�¦ã�„ã�¾ã�™ã€‚スレーブアドレã‚...
