MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! LSM9DS0 eliminate LA_TyOff
In the datasheet, it says that LA_TyOff can be eliminated by enabling built-in high pass filter, but for accelerometer, the high pass filter can't be disabled (I assume that the normal mode means high pass filter is enabled, in CTRL_REG7_XM). I had a...
PTsen by Associate III
  • 2368 Views
  • 6 replies
  • 1 kudos
Using VL53L0X with STM32L476 Nucleo64?
Posted on March 05, 2018 at 16:43Hi,I am a novice trying to work on some sensors by connecting them to the STM32L476 nucleo 64 board. Currently I am trying to use the Time of flight sensor, VL53L0X breakout board, by connecting it at the I2C pins on...
va vai by Associate
  • 1488 Views
  • 1 kudos
H3LIS331DL capture drop events
I am using an H3LIS331DL accelerometer on a custom PCB. I wish to use it to attempt to capture some drop events. Using an analog accelerometer, I have seen that the drop event occurs within approximately 1-1.5 msec. Will this accelerometer be able to...
MMacL.12 by Associate
  • 1128 Views
  • 1 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
