MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Some general info on the SensorTile.box (TileBox) required
So, i can operate the sensor box, install the updates a couple different ways and generally get it to work. But, the TileBox has three switches on board, none of which are accessible from the outside without adding some holes to the case. The TileB...
TJM by Senior II
  • 2122 Views
  • 5 replies
LIS2DH 6D mode not working properly
Hello,I am trying to implement 6D mode. I am following 1:1 the code documented in the design tip DT0097.I have been trying for a while: I2C interface is working and other modes of LIS2DH work properly.As a safety measure, during the init I reset all ...
vcaia.1 by Associate II
  • 1708 Views
  • 6 replies
MEMS Accelerometer application
HI Guys, I am looking for the MEMS Accelero meter for measuring the vibration in textile machines. Whether ST has the application example for condition monitoring system in machine or industrial automation.If so please share the details
NGopa.1 by Associate II
  • 2155 Views
  • 5 replies
Resolved! MotionAR Initialize function gets stuck
Posted on January 24, 2018 at 17:10I am trying to add MotionAR library to a DataLogger sample application running on SensorTile. I manager to compile the library and program my chip with it. Near the top of my main() I added simple MotionAR_Initiali...
Norman S by Associate II
  • 2228 Views
  • 3 replies
  • 1 kudos
I'm want to acquire rawdata from the SensorTile.box (Steval$MKSBOX1V1). Using the app, I can get 16bits output raw data when Bluetooth streaming and then sending the files to email, but it's very limited.
How to I get control over the output data format? Is there a way I can upgrade the firmware, without any additional hardware (just using USB cable and STM32Cube IDE or Programmer) to change how I record the data?
MMarq.1 by Associate
  • 1839 Views
  • 3 replies
