MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Algobuilder IIR Filter a10/a20 coefficient
Hi!I am using the IIR function block in Algobuilder. In the UI I can enter the coefficients manually or use a file. The implementation uses the CMSIS functions Biquad Cascade IIR Filters Using Direct Form I Structure (void arm_biquad_cascade_df1_init...
DWind.1 by Associate III
  • 1313 Views
  • 1 replies
Export raw accelerometer- and FFT-values from Unicleo
Hi!I have a Nucleo board and use the FFT example that comes with Algobuilder. It shows all the data and the results from FFT in the separate window. I would like to export all the data (accelerometer values, FFT results, peaks, etc). It works with ac...
  • 1014 Views
  • 1 replies
LSM6DSL does not respond well anymore
I was testing the LSM6DSL, at first 10 versions of my firmware, the sensor is working fine, I was able to read and write to its register. Now it does not work, reading the WHO_I_AM register gives different value than 0x6A. I hope you can help me.
JBrio.1 by Associate II
  • 1781 Views
LSM303AGRTR minimun configuration as temperature sensor
Good afternoon,My name is Jorge. I am an firmware engineer from Sayme Corp in Spain.I am using an LSM303AGRTR acceleration and magnetic sensor to get temperature values.I am following the instructions from the datasheet:"4.5 Temperature sensor The LS...
JGonz.1 by Associate II
  • 1380 Views
  • 1 replies
How to change meta data of IIS3DWB
Hi,I got a doubt while i was studying IIS3DWB data sheet, "Meta information about accelerometer and sensor configuration changes can be managed by enabling the ODR_CHG_EN bit in FIFO_CTRL2 (08h)". But , i have not found that bit in FIFO_CTRL2 registe...
JPale by Associate II
  • 1349 Views
  • 1 replies
  • 1 kudos
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
