MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Vl53L0X Offset Calibration
Hello,I am currently trying to implement offset calibration to VL53L0X sensor. I placed sensor in front of white paper with 100mm distance as datasheet suggest. When I get sensor measurement before offset calibration, I get 135mm which is fine becaus...
TGund by Associate
  • 1639 Views
  • 1 replies
  • 1 kudos
LIS2DH12 ACC Reading Problem
Hello,I am using LIS2DH12 with SPI connection. I am able to read back Device ID which is 51. Also, I can write a to the reference register and read back successfully. However, I cannot set registers. I am writing value on it and read back. The value ...
ESims.2 by Associate
  • 1225 Views
  • 1 replies
Estimating random walk of ISM330DLC
Hi,I am having uncertainties when calculating displacement and change of angle effected by random walk.I want to know proportion of failure in measurement caused by random walk.In the datasheet of ISM330DLC random walk (ug/sqrt(h) is declared as nois...
APfel.1 by Associate
  • 1665 Views
  • 1 replies
Potting an accelerometer (LIS2DS12)
I'm wondering if there are any concerns with acceleration measurement offsets and extra noise due to strain on the package from encapsulating it or potting it. I'm specifically looking at the LIS2DS12 if different packages have different answers to t...
KOlso.1 by Associate
  • 1231 Views
  • 1 replies
LSM9DS1 offset
Hi all,I did a firmware in python for LSM9DS1 and I red the register 0x18 with autoincrement but I noticed that there is a offset in gyroscope for axis x,y,z. So I did the single reading for the register but there is always an offset. How can I do t...
FPugl.1 by Associate
  • 1277 Views
Updating firmware for the Sensor Tile Box Using the IOS app fails.
I am trying to update the firmware on my Sensor Tile Box (STEVAL-MKSBOX1V1). The current version on my Sensor Tile Box is 3.3.5. On startup, The IOS app indicates that the new firmware V3.41 is available for the box. However, trying to update to this...
KJala by Associate
  • 784 Views
  • 1 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
