STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1426 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 558 Views
  • 0 replies
Nucleo H745ZI_Q board ADC issues when using ethernet
Hello i have a Nucleo H745ZI_Q board in this Ethernet is working fine but  when am going to configure ADC  all the three ADCs are shows error message --> Partly Disabled conflict with: ETH: mode RMII   even many channels also showing error message (i...
SA  V.1 by Senior
  • 4497 Views
  • 9 replies
STM32CubeIDE and C# / .NET Nanoframework
Hi,As a C# application developer, are there any plans to integrate C# with .NET Nanoframework into STM32CudeIDE?I know there are ways to do it with Visual Studio. But this also incurs a different bootloader firmware to be flashed. And this is only va...
GDR by Associate
  • 2457 Views
  • 0 replies
Resolved! STM32F030F4P6TR + ADC
Hello. I am new to STM32F030F4P6TR programming, so I am asking for your help. You need to write a simple program to light up the LEDs depending on the voltage. But I have some problems with the ADC. To begin with, I wrote a simple program that flashe...
Need Support regarding Drivers of STM32 F401 board.
Hello Everyone,I wrote the code by self for GPIO drivers , as a step by step process i am adding code for other peripherals & buses after taking due time in learning , the code progress as of now (as per my knowledge) should be enough to enable the G...
How to customize a STM32CubeIDE code generator for my board?
It's been quite a while since I started to work on various MCUs with STM32CubeIDE.As it was quite magical at the start, now I roughly understand how a project is configured, especially what files are needed for what, where are they located, how they ...
HTD by Senior III
  • 6969 Views
  • 2 kudos
STM32H750 CubeIde MPU setting ignored
Hello, I am trying to get Ethernet working, I don't like HAL, switched all is possible to LL library. @Piranha​ Hi, if this is a bug please add to your report if someone try use LL configuring Ethernet. Platform LinuxCUBEIDE Version: 1.7.0STM32Cube_F...
RRoma.4 by Associate II
  • 2991 Views
  • 1 replies
  • 1 kudos
