BHuss.2
Visitor II
May 18, 2023
Why do the standard libraries discard at the end of the linker file /* Remove information from the standard libraries */ /DISCARD/ : { libc.a ( * ) libm.a ( * ) libgcc.a ( * ) }
  • May 18, 2023
  • 1309 views
Tesla DeLorean
Guru
May 18, 2023
Probably to remove any clutter or associativity brought along by inference or use elsewhere.
Think garbage collection, or dead-code removal.
You could perhaps not do that, and see what clutter ends up in the .ELF file?
Pavel A.
May 18, 2023
Because the ARM and CubeIDE gcc toolchains come with other standard libraries. They don't have names "libc" or "libgcc" or "libm".
This snippet in the linker script can be safely removed, unless you use some other toolchain.
