STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1671 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 627 Views
  • 0 replies
Resolved! "Unable to launch" error after stm32cubeide update
Hi all,I'm having an issue with a pre-existing project. It was initially built a few months ago on version 1.16 of the IDE, and confirmed to be working. I have since updated to stm32cube ide version 2.1, and am having an issue with this project not b...
STM32CubeIDE 1.14.0 flto build warning
Hello. I have the following problem. When I enable flto optimization in a (freshly generated) project, several dozen warnings appear during compilation.Sample warnings:Drivers/STM32L4xx_HAL_Driver/Src/subdir.mk:88: warning: pattern recipe did not upd...
SKape by Associate II
  • 15186 Views
  • 27 replies
  • 20 kudos
stm32 cubeide: How to modify C language parallel compilation
How to configure parallel compilation in cubeide, that is, "j-4" "j-8" and I encountered an error in the Windows 87 code, how to solve it, I changed the path and still couldn't do it····································································...
CubeIde 2.1.0 Error with J-link
Hello,I have been using CubeIDE for some time to flash the STM32H755ZIT6 microcontroller with the J-Link Base. After the latest update, I started getting this error: Error in final launch sequence:Failed to execute MI command:target remote localhost:...
Debugger steps and runs slowly
I started learning embedded systems recently, and have been using the Nucleo-F303RE board with the STM32CubeIDE toolchain. Recently, I compiled a program and started stepping through it in the debugger. Everything worked fine as always. I started to ...
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
