STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1447 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 566 Views
  • 0 replies
"make -j8 all" terminated with exit code -1
Hi,I am trying to build on STM32Cube IDE, it is showing that "make -j8 all" terminated with exit code -1. Build might be incomplete. Then while trying to flash or debug it is not working. I tried to  disable parallel build, but still this issue I am ...
Bsm01 by Associate II
  • 1955 Views
  • 3 replies
  • 2 kudos
Resolved! What is required for live expression support
I am trying to use live expression on an STM32G0 with an Stlink V3minnie. It's not allowing me to read any variable even once. I read that the variables need to be global. Is this true? Does this mean class variables also will not be supported but on...
Carl_G by Senior III
  • 1059 Views
Bugs in STM32Cube IDE
I am facing lot of issues while using STM32Cube IDE.It seems there are lot of bugs, which makes the IDE inconsistent & time wasting.
  • 865 Views
  • 1 replies
  • 2 kudos
Resolved! C++ with STM32CubeIDE
Hi,So I have been trying for last few days to port a library from Arduino and I am using STM32CubeIDE to generate code for the peripherals as it would be quick for my work and I do not want to change the Arduino code much other than the required thin...
Build terminate with exit code -1.
Hi All,I compiled my code, no error no warning, but I get this code below. Also, when I try to run the code, it is not uploaded to the board.Could you pls check for me ? **** Incremental Build of configuration Debug for project Boot ****make -j8 all ...
demir by Senior II
  • 4136 Views
  • 4 replies
