STM32 MCUs Wireless
Hi, As per UM3610 « section 7.7 », a "Bootloader limitation" has been found in NUCLEO-WBA25CE1. Please refer to "Workaround" section if you are facing this limitation.
ctrois by ST Employee
  • 218 Views
  • 1 replies
  • 1 kudos
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 4064 Views
  • 0 replies
  • 3 kudos
About SysTick with STM32WL55
Hi I am testing SysTick with STM32WL55.I set the IOC file as follows.​When a break point is set in HAL_IncTick() in SysTick_Handler() and the program is executed in debug mode, the program does not stop here.In other words, the SysTick_Handler() func...
Resolved! About STM32WL55
Hi.I am using STM32WL55 for FSK communication.Firmware version is STM32Cube_FW_WL_V1.3.0.In the past, version 1.1.0 was used, but version 1.3.0 has changed a lot.So I'm not sure how to set it up.​​First of all, I want to set SUBGHZ_PHY, but the Enabl...
GPIO CONFIGURATION
basically I'm working with a LoRaWan card that mounts your STM32WLE5CCU6 microcontroller.the problem arises from the high consumption of my product.I'm trying to program the PA8 pin of the microcontroller as an input that is always under VDD and I've...
rib.1 by Associate II
  • 3362 Views
  • 4 replies
Resolved! STM32WLE55 - new created STM32CubeMX files not building
Hello, we want to use the STM32WLE55 MCU in the AI50H Module to build a Node to Node connection in a LoRa Network.So i used the STM32CubeMX Program to build an easy solution that includes only "UART", "SUBGHZ" and "SUBGHZ_PHY" modules. Goal is that i...
Draegi by Associate II
  • 3667 Views
  • 5 replies
プロファイルサブシステム QDID 122688 �?�内容�?�よ�??�?�?�り�?��?�ん。カスタムプロファイル�?��?��?��?�も該当�?��?��?��?�。
STM32WB5MMG�?�STMicro�?�ら�??供�?�れるLibrary,Driver,FUS_fw,BLE_Stack_full_fw,BLE_Otaを利用�?��?��?カスタムプロファイル�?�BLEを�?�載�?��?�製�?を開発�?��?��?��?��?�。�?�れを販売�?�る�?��?�?Bluetooth SIG�?証を�?��?��?��?��?�考�?��?��?��?��?�。QDID170767,160724�?�該当�?�る�?��?�?れ�?��?��?...
hueta.1 by Associate
  • 1406 Views
  • 1 replies
Implement clock synchronization - undefined reference to functions (STM32Cube MCU Package for STM32WL series 1.0.0)
Hi everyone,I use the  STM32CubeIDE 1.6.0 and the STM32WL package 1.0.0I am trying to implement the clock synchronization feature but I cannot get the application to be built.I enabled the with the following definition#define LORAWAN_DATA_DISTRIB_MGT...
_legacyfs_online_stmicro_images_0693W00000bhkuOQAQ.png _legacyfs_online_stmicro_images_0693W00000bhkuYQAQ.png
