MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
eMotion FW - cannot download to STEVAL-MKI109V2
Posted on October 04, 2013 at 11:52Hi, I have a 109V2 and the 10-axis module 124V1. I want to customize the FW for logging, but there is a problem at the step 4: 1. Use Dfuse Demo to download the DFU patch and eMotion FW without any problems, all lo...
minhdat by Associate
  • 1307 Views
  • 1 replies
SD interface in high speed mode
Posted on October 10, 2013 at 21:48Anyone with experience on SD/MMC interface used in High Speed mode (48MHZ) for SPEAr320S? Seems like the timing could be an issue for some cases.
fredrik by Associate
  • 972 Views
  • 0 replies
what is the SDI of LSM9DS0?
Posted on September 27, 2013 at 08:59I'm preparing a new design with LSM9DS0. I want to use the SPI interface, but the datasheet does not solve my curiosity. (The datasheet which I refered is DM00087365.pdf - August 2013, DocID024763 Rev 2) Accordin...
just4u78 by Associate II
  • 1513 Views
Accelerometer
Posted on October 04, 2013 at 08:12Hello, I am working with LIS302DL Accelerometer. How can i get the real time acceleration? Is it possible to calculate distance using 3 axis data of accelerometer? -Amreen #lis302dl
purchase by Associate
  • 1269 Views
  • 1 replies
What is sensor fusion?
Posted on September 07, 2013 at 18:21What is sensor fusion? #motion-sensor #inemo #sensor-fusion #sensor-fusion #inemo
Higher rate gyro's
Posted on September 19, 2013 at 12:11Are there any plans to produce higher rate gyro's - we are looking for 6000 deg/sec. Low power, digital if possible, triple axis.What volumes would we need to commit to in order to warrant a product like this bei...
Which Sensors are fit to be used under automotive guidance
Posted on September 18, 2013 at 11:53You have the category http://www.st.com/web/en/catalog/sense_power/FM89, and there the column MEMS and Sensors.Can I use every Sensor there for automotive applications or do you have a separate marking for that?I...
Data output format of the LSM303DLHC
Posted on September 17, 2013 at 15:53Hello!I have a question about the LSM303DLHC. In the data sheet i can't found any information about the output format for the acceleration and magnetic data. Therefore i thought it works with 16-bit values. While...
oliver2 by Associate
  • 933 Views
  • 1 replies
Gyroscope being off rotation axis
Posted on September 11, 2013 at 16:41Hello,How will gyroscope work if it isn't on rotation axis, but shifted about 1.5 cm off it? Will it still be usable to measure rotation angle? Or such case won't work and gyroscopes output data will be false? ...
andis by Associate
  • 987 Views
  • 1 replies
