MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
driver steval MKI062V2 for Win8
Posted on October 23, 2013 at 20:58Is it possible to download a driver for the steval MKI062V2 Inemo board in order to use it with windows 8?
caron by Associate
  • 1047 Views
  • 1 replies
lsm9ds0 i2c interface
Posted on October 25, 2013 at 02:32I am getting data from the gyro from i2c address 0xd6 but I can't seem to get any response from the accelerometer at i2c address 0x3a.  Can anyone share any i2c code that works with accelerometer on this chip? #...
clovett by Associate
  • 761 Views
  • 0 replies
L3GD20 DRDY signal issues
Posted on October 21, 2013 at 14:34Hello.  I want to process each set of readings from the L3GD20 as they become available.  The DRDY signal seems the most appropriate way to do this.  I've verified with an STMicro engineer that my register settings...
rich by Associate II
  • 1378 Views
Eval STEVAL-MKI073V1 doesn't work with stsw-ekang
Posted on October 22, 2013 at 01:52Hi, I purchased the evaluation kit STEVAL-MKI073V1 and downloaded the driver and GUI tool on its product page. The software recognizes the board as Device LSM303DLH, firmware M303DLH 0.5, Software version 1.0.16. N...
jwyrwas by Associate
  • 1161 Views
  • 1 replies
LIS3DH Internal Pull-Ups
Posted on October 03, 2013 at 01:43HelloAt the LIS3DH Datasheet is stated that there are internal Pull-Ups at all SPI pins of the LIS3DH. How much is the approximate value of the pull-up resistors? According to my experience, with the CS tied high, ...
luisf by Associate II
  • 1186 Views
  • 1 replies
L3G4IS
Posted on October 15, 2013 at 01:40There is a L3G4IS http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00044913.pdf that has an OIS (image stabilization) mode that gives an ODR of 9.5KHz - I couldn't find any detai...
eMotion FW - cannot download to STEVAL-MKI109V2
Posted on October 04, 2013 at 11:52Hi, I have a 109V2 and the 10-axis module 124V1. I want to customize the FW for logging, but there is a problem at the step 4: 1. Use Dfuse Demo to download the DFU patch and eMotion FW without any problems, all lo...
minhdat by Associate
  • 1286 Views
  • 1 replies
SD interface in high speed mode
Posted on October 10, 2013 at 21:48Anyone with experience on SD/MMC interface used in High Speed mode (48MHZ) for SPEAr320S? Seems like the timing could be an issue for some cases.
fredrik by Associate
  • 963 Views
  • 0 replies
