MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
STEVAL-MKI117V1 audio output
Posted on January 12, 2015 at 16:48Hi, I'm runnig a small research project with the STEVAL-MKI117V1 evaluation board. At the moment I'm facing some problems with accessing the audio data stream. Hopefully someone can answer my questions: 1. Is it p...
iNemo M1 firmware?
Posted on October 09, 2013 at 10:07Hi guys,I just received a couple of iNemo M1 boards (http://www.st.com/web/en/catalog/sense_power/FM89/SC1448/PF253162). It's a nice little gem, and I look forward to design great stuff with it. However I have not ...
LPS25H SPI driver for steval-mki062v2
Posted on January 08, 2015 at 16:43 Hi all, I have to connect the LPS25H sensor with the steval-mki062v2 board through the onboard 10-pin connector J8 and use the SPI1 for communication; I want to use the same iNEMO firmware provided with...
andyeh88 by Associate
  • 1010 Views
  • 0 replies
Current consumption LSM330D
Posted on January 07, 2015 at 18:05I have read and re-read the data sheet on this device. In sleep mode for the gyro and active mode (50 Hz) for the accelerometer I expect a current consumption of 5 + 11 = 16uA. In reality I measure 120uA - 140 uA. ...
LSM9DS0 Chip Select
Posted on January 01, 2016 at 18:23Dear Community, I'm implementing a design with LSM9DS0 in SPI communication mode I have a question about the following CS pins 19 CS_G 20 CS_XM Did they work as normal CS SPI Pins or I just to pull them to 0? BR ...
Output Data Rate / Bandwidth of Accelerometers
Posted on December 28, 2014 at 20:21Hey,For my project I need the highest output data rate/bandwidth possible. I also need to sense high g impacts (>100g). Currently I am using the H3LIS331DL and getting 1KHz output data rate with +-100g/250g range....
mjdietz2 by Associate
  • 691 Views
  • 0 replies
Datasheet for LSM303DLHC
Posted on December 27, 2014 at 19:22Is there an updated data sheet for LSM303DLHC? In datasheet DocID018771 Rev 2 some informations once covered in former products just have been dropped. Such as ADC conversion range / scaling of measurement value...
jjonethal by Associate II
  • 1089 Views
  • 0 replies
STEVAL-MKI109V2
Posted on December 18, 2014 at 06:49I purchased a STEVAL-MKI109V2 and it did not come with any software.  After some searching of the web site I found the user guide and some software guides but no actual software.  I found a software page for http:...
wef by Associate
  • 1925 Views
  • 1 replies
