MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
I design a battery powered BT Tag using LIS3DE. I want to detect movement as a trigger to transmit BT beacons. Which mode should be choose if I want to reduce the power consumption.
LIS3DE connects to BLE IC using I2C Bus and INT pinsPlease state the mode according to time before and after the trigger.Second, if I want to monitor 30 seconds after trigger to double check is it need to transmit BT beacons. May I use LIS3DE FIFO to...
MotionFX: Different between implementation for M0 vs. M3
Hi,i am trying to use the MotionFX library on M0 MCU for LSM9DS1. As result i read the rotation_9X structure and use yaw as heading for compass result. The result showing the rotation but i see the offset on the Z axis of the gyro and the heading res...
drozel by Associate II
  • 2267 Views
  • 6 replies
Cannot access mag registers on LSM9DS1
On about 15% of the boards in my latest production run I am able to access the accel/gyro registers over the I2C bus but cannot access the magnetometer registers. As a simple test I am trying to read the WHO_AM_I register (0x0F) for both. I get the...
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
