MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
No data from lsm9ds1
Hi,I am using the lsm9ds1 with a selfmade circuit, but I could not get any data from the sensors. The I2C works fine. I can access the registers, read and write to them and get an acknowledge from it, but when I read the data registers, the values do...
What is the purpose of GPIO in VL53L1x Time of flight sensor.
Could anybody explain me about the purpose of GPIO that present in the sensor. How can we use that for an application, then there is a constant output voltage at range of 3v3 (when we give input voltage as 3v3 to sensor to work) is this voltage can b...
BBaby.1 by Associate
  • 1105 Views
  • 1 replies
Resolved! LSM9DS1, FIFO, Duplicated data
Hi,I'm acquiring gyros and accelerometers data through i2C bus, pulling the data from the FIFO asynchronously from the component acquisition frequency, but at a frequency close by (to avoid overfilling the FIFO).Without metrological tools, I can sti...
wpaul by Associate II
  • 2987 Views
  • 5 replies
LIS3DH consuming too much current
Any ideas why LIS3DH is not consuming current as per data sheet which is 6uA whereas I am getting about 200uA.I have kept CTRL_REG0 at default.Would could be the problem?
ameeruak by Associate II
  • 3964 Views
  • 6 replies
