Question from Predictive Maintenance Webinar 29th of April: is the product prepared also for industrial use? With IP65 protection,, mounting solutions?
Question from Predictive Maintenance Webinar 29th of April: Hi , can you please give us an idea about the cost of this system
Question from Predictive Maintenance Webinar 29th of April: Hi, what do you think about analog MEMS accelerometer in condition monitoring? Is this only an old technology or there will be future?
Question from Predictive Maintenance Webinar 29th of April: Is it possible to connect such hardware to predictive maintenance matlab toolbox?
Question from Predictive Maintenance Webinar 29th of April: For PdM the demos, are there possible combinations of vibrometer and microphone?
Question from Predictive Maintenance Webinar 29th of April: The ODR of the data logs changes from the set ODR, in fact we have measured ODR which can be more than 5 % different from the set ODR. why is so...
Question from Predictive Maintenance Webinar 29th of April: What is part number of microphone for ultrasound detection used here?
Question from Predictive Maintenance Webinar 29th of April: In the webinar you did not mention much about documentation. What is avaialble specifically for the vibration sensor and STWIN ?
Question from Predictive Maintenance Webinar 29th of April: What's the difference betw. a vibration sensor and an accelerometer?
Question from Predictive Maintenance Webinar 29th of April: How high bandwidth can the magnetometer provide for motor monitoring?
